16-05-2024 06:13 AM
Please help, I am in Kenya and not receiving txt messages which I can normally if I need to verify certain UK accounts. Please help me solve this as I have been trying since arrival last week.
16-05-2024 07:59 AM
Hi @Abygacenia
Can you receive calls and send texts?
Do you have a pay as you go or pay monthly account?
Leanne 🙂
16-05-2024 08:06 AM
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
