Phone not showing incoming call
Tenpin
I have an account with NSI which requires two tier sign in , first on the website , then they ring and I put in the 6 digit number from my website page . But my phone doesn’t ring it just goes straight to voicemail
it use to work until the last apple update
any ideas please
15 REPLIES 15
Leanne_T
Hi @Tenpin
Thanks for coming back to us.
If you could try deleting and re-installing the contact to see if this helps? It may also be worth trying the SIM in another phone to see if you can receive the call? This would help us to see if this follows the SIM card.
Leanne 🙂
Can’t delete the contact it’s the N S I two tier identification code phone line
Going to add another phone number to my account see if that  rings for the ID code  phone line line
I will keep you updated
A two-way SIM-swap may be wise here. It will categorically identify whether the phone is at fault or not.
Test a working SIM in the non-working phone - what result?
Test the non-working SIM in a working phone - what result?
Swapped sims . Got through ok
so obviously a phone fault
trade in tomorrow
trade in tomorrow
SIM card swapped worked
so old phone getting traded in tomorrow
thanks for the help
