Paid to use phone overseas but can’t connect when trying to call UK from Canada
SJMS
@SJMS  You’ve purchased an add on to use your allowances while there,   you still have to enable roaming and call abroad and make premium rate calls from within your online account.   These are not the same thing.
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
On contract. Yes unlimited in uk and I paid for access in Canada but have not been able to make a single call. Just states “call failed” each time!
James_B
EE Community Manager
Hi @SJMS,
Have you activated roaming in My EE? If not, go to Menu > Account Settings > Parental and Data Controls.
