Outgoing calls have suddenly stopped when abroad
Forest79
I’m currently abroad (Spain) and was able to make calls both locally and back to the uk. Suddenly I’m now unable to make any calls. My plan says I can currently still use my data, anybody know what I can do?
Katie_B
Hello @Forest79
Welcome to the community.
Do you have an active roaming pass on your account?
Are you aware if there is a spend cap in place?
Have you tried manually connecting to another local network?
Katie
Yes to all above
Katie_B
Thanks for confirming @Forest79
What is your spend cap set at?
Can you still receive calls OK?
Katie
Don’t know my spend cap
yes I can receive calls
Leanne_T
Hi @Forest79
You can check the Spend Cap limit if you log into your My EE app, select Settings and Permissions, Spend Cap, what is this set at?
Leanne 🙂
