WiFi Calling stopped working
SKL17
HI, Did this get resolved please and if so, how was it fixed? I am now getting the same issue- it suddenly stopped working. I have reset the network settings on my iPhone air and it worked for a few mins and then stopped again. Very frustrating as I don't have any standard phone signal so am unable to make or receive calls.
Your post has been moved to a dedicated thread.
To clarify, the thread you'd added to, was regarding a user who'd travelled abroad and been roaming, then returned to the UK and was unable to use WiFi-calling. Is this the case for yourself also?
Did you use your phone on EE's UK network between roaming & relying on WiFi-calling?
Northerner
Hi @SKL17
It will only work if there is no network. If the network signal is adequate the service won't activate.
Alternatively turn on airplane mode and activate WiFi.
Sofaslug
Valued Contributor
Valued Contributor
I still have intermittent issues with a Samsung 23 Ultra. I dont think there is a fix as such. Try phoning ee and asking them to check your firmware is upto date - I recently had to have mine forced through as it hadnt updated automatically. Does your phone use WiFi 7? Mine doesnt so dont know if a phone with WiFi 7 will work better with this hub? You can also try restarting your hub via the app - I found sometimes that deleting the app and re installing sometimes helps the router- could just be me?
You can check your device's firmware is current, by following Settings > Software Update on most Android phones. EE-CS have no way of checking this.
