on 19-09-2023 10:01 AM
I've got my BT PAC code, I've got my new EE SIM card in my phone and activated with the number it came with. I registered for myEE, I've put my PAC code in the EE online form https://myaccount.ee.co.uk/keeping-your-number/ and entered my old number etc but it keeps throwing me an error message saying the PAC code is not in the correct format (ABC123456) but the number I entered is definitely in that format (3-letters followed by 6-numbers)!!! I've tried copy and pasting the PAC code from BT as well as typing it in manually to no avail... What's going on?
on 19-09-2023 12:19 PM
Hi @gavla80
Welcome to the community. 🙂
You shouldn't have to use a PAC, it should be set up to automatically port from BT to EE the next working day after registering the EE SIM.
on 19-09-2023 12:22 PM
OK, thanks for your help. Hopefully it will all be sorted automatically by tomorrow!
Cheers
on 19-09-2023 12:25 PM
Let us know what happens please, @gavla80. It's usually done quite quickly during the day, but it can take up until midnight.
on 19-09-2023 07:12 PM
I have experienced exactly the same problem as @gavla80 so it might be worth checking that your transfer form hasn’t got an error
on 20-09-2023 09:34 AM
Hi @Helen205,
How did you arrange your move to EE? Did you go through it with a member of the BT Team?
If you did, they will have already set up your number transfer for you.
on 21-09-2023 10:50 AM
Thanks for the feedback, @ashanthm. Glad you managed to get the port sorted.
