Not able to send / receive TEXTs while abroad - PAYG (calls work)
dps1976
Hi - I'm currently abroad - On PAYG - active SIM - I can make and receive calls (ie roaming works). I can send texts to 150 (check balance etc) and I also receive replies from 150.
My issue is that I am not receiving any other texts and also not able to send any texts
Please help
thanks
dps1976
Hi guys,
thanks for the reply - managed to sort it out by doing the following
1) after (another) reboot I was able to send TEXTs but still not receive any
2) I then switched my wifi off and set my EE sim as my default data sim, enabled roaming etc - I got a prompt to sign in to the local network which took me to the EE page to buy a roaming add-on. After this step I also started receiving new TEXTs
thanks for the help
@dps1976   Abroad is a big place where are you exactly ?
Leanne_T
Hi @dps1976
Thanks for posting.
Have you tried restarting your phone?
Where are you roaming at the moment?
Leanne 🙂
dps1976
Hi guys,
thanks for the help
Leanne_T
Thanks for letting me know @dps1976
Leanne 🙂
