No signal abroad
MaxenceBoggio
I recently arrived in Singapore and am unable to have any signal on my Iphone and when I try to activate "Enable Roamin" it shows me an error and asks me to text 150 to get more info, which I cannot do as I have no service on my phone...
Any suggestions on what I should do?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
