No phone network abroad
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
25-07-2024 06:53 AM
I have arrived in Denmark from uk and have no access to the phone network - I can access wifi. I had the same issue in Italy last year, which took EE a couple of days to solve - the first level support said everything was set up ok. I have roaming data included in my plan. I have an eSIM which gives me a number of options - I’ve tried several combinations without success. When I switch off automatic network selection, it just searches without bringing up any options
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
25-07-2024 10:15 AM
Hi @Popcorn100
Did you text ROAMING to 150 before travelling to make sure roaming was active as well as having the add-on?
Leanne 🙂
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
25-07-2024 10:32 AM
- Finland -EE mobiles no longer working in Finland & 150 calls do no work! in Roaming
- SMS messages show wrong number after porting to EE (Samsung S25 Ultra) in SIM cards & Porting
- Received EE txt of network upgraded & reboot phone. What upgraded ? in Mobile Network discussions
- I can’t make calls from abroad in Roaming
- 4G/5G Network Bands in Mobile Network discussions
