No data
Cezza1
I have no data abroad and I’ve got the roaming pass
@Cezza1 : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
Maliq1982
did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on  device. Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto.
If not, call the EE-center. They will fix that problem ASAP.
