No data connection abroad
MikeyClax
I'm in Slovakia and have been for 10 days. Yesterday I exceeded my data cap( self set ) so my phone.wont work. I've changed my cap, I haven't exceeded my actual contractual allowance by the way. I can't call EE because when I dial dial 150 it just connects me to the emergency services here. I txt BALANCE to 150 and it said  £18.74 to go onto my next bill.  £2.47 a day to use my phone here so I should owe more than £18 but it's not showing on the usage breakdown. When I texted BILL to 150 and now I'm panicking because it says " the balance for your device is £289.96. how do I get in touch with EE to get my phone working again and to find out how much I've spent / owe?
A data cap should only affect mobile data usage, it won't have any bearing on voice calls or text messages.
You can contact CS on +44 7953 966150 from abroad - 150 sometimes works, but the long-dial "will" work. I wouldn't be surprised if there's a day or two's delay in the daily charge being added to your bill, although any more than that and I'd get suspicious.
@MikeyClax : EE can be confusing when it comes to showing charges with regard to VAT. In its bill all charges are VAT-inclusive but for interim charges to be added to next bill it confusingly uses ex-VAT charges.
You are still on your 10th day, so you've only been pre-charged for 9 days.
The daily roaming charge is 2.058 ex-VAT. So you're being charged £18.53 ex-VAT which is about right!
Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Thanks for your help. The long number worked off someone else's phone. Customer service sorted me out. I had changed my spend cap from £20 to £40 after receiving the message off EE that I could lose services like texting and calling. There was just a longer than usual delay in it going through.
Thank you for your generosity and advice. You were spot on about the billing and charges!
