MyPlace daily messages
Halfpint2011
Hi, Is anyone getting a MyPlace message daily to say it's taking longer than expected to fix the problem near home? What is MyPlace as it is getting really annoying now?
Leanne_T
Hi @Halfpint2011
Thanks for coming here.
You will receive these updates if you have requested updates from the EE Coverage & Network Status Checker for an area.
You can remove this by going to Manage saved locations and entering the number on the EE Coverage & Network Status Checker.
Hope this helps 🙂
thank you! How are there problems in my area everyday? My signal isn't great and I already use wifi calling?
Leanne_T
They would be reported by other customers and updates would be sent to let you know this is being looked into @Halfpint2011
You can remove these if you no longer want to be made aware of any problems we are investigating in the area.
