Morocco travel
hoozjimbo
I want to be able to call...
1. Moroccan landlines and mobiles
2. UK mobiles
Is there a good package? Please provide pdf terms and conditions.
As it is not in EU, you cannot use your usual UK allowances there but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/morocco.
If you are on contract, remember to text ROAMING to 150 before you leave UK to ensure roaming is enabled on your account.
If you are on PAYG, make sure you have used your PAYG SIM to make a call or text before leaving the UK.
hoozjimbo
Thanks.  This is a suggested add on for the phone use.
But the terms are very badly described.  Will it allow me to make calls from my phone to Moroccan landlines and mobile phones for free?
Can someone send me a pdf link with the relevant terms and conditions?
Thanks, James
Yes, it says "the country you are ravelling in".
See Pay monthly roaming plans Terms and Conditions
