DATA not working in France
Mrf1219
My data won’t work in France what do I do? My phone only works on wifi.
10 REPLIES 10
@Mrf1219  Did you activate roaming on your account If you’re a contract customer before you left the UK ?   Or are you a PAYG customer? You’ll need an add on in order for this to work
@Mrf1219 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
On my account in the app it says prepay? I have subscription back that renews every 30 days, would that be Pay as you go? i can’t find the roaming on my account it doesn’t show it to me.
That's PAYG.
Did you receive a msg upon arrival telling you about the charges for roaming in EU on PAYG? Did you buy 1 of the "Roam Like Home" add-ons to be able to use your UK pack allowances there?
Please see our Pay As You Go charges for roaming in the EU, Help page for more details.
Does your phone show a connection to any French networks?
Yes I did buy on upon arrival but it hasn’t worked. I have bars on my phone but once I go off wifi it doesn’t work.
Yes, but they aren’t working.
Christopher_G
Did you use your phone to make a call or send a message whilst you were in the UK, before travelling, @Mrf1219?
Yes I’ve been using my new sim since august!
