on 22-06-2022 07:32 PM
Hi having terrible signal issues since losing WiFi calls as changed to Bt for internet. Any suggestions to improve re phone signal
on 22-06-2022 07:39 PM
Hi yes it's a network issues across the whole UK. I've had issues to connect to. So had to stay in to stay connected on WiFi. I use alot of what's app and social media for my connection and its been terrible. I just hope it's resolved by tonight and also EE compensation to all account holders for the inconvenience caused.
on 22-06-2022 07:50 PM
In amongst well-meaning posts referencing the current issues, this sounds like something different.
The mobile network signal is what it is, but what do you mean by "losing WiFi-calls as changed to BT for internet"? EE WiFi-calling works over any broadband connection, it doesn't need EE broadband.
If you can explain your issues, I'm sure some help can be offered.
on 22-06-2022 08:36 PM
Thanks for that info as I was told WiFi calls only worked with the same internet provider
