on 02-07-2024 12:16 PM
Solved! Go to Solution.
on 02-07-2024 12:55 PM
Hi @LeninVsashka77,
Unfortunately this wouldn't be an issue that could be resolved by EE themselves as the issue is one that has occurred with the device manufacturer. If you are having issues accessing your Google account, you can follow the steps here to regain access to your account.
Hope this helps.
on 02-07-2024 12:19 PM
Hello @LeninVsashka77
What do you mean locked out? As in forgotten your pin, password or pattern to your phone?
Or forgotten the Sim Pin?
on 02-07-2024 12:22 PM
on 02-07-2024 12:35 PM
With the phone number you choose the country for example UK +44 7123456789. Put in 10 digits and miss out the first 0
Check your Spam/Junk incase they land in there.
If all fails then I suggest you contact Google Support
Hi @LeninVsashka77,
Hope this helps.
