ROAMING
ChrisJuly
Hi all.  Really struggling here and no support from ee.  (Were supposed to call back and didn’t and been round in circles with their text service.)
I am in Italy and have been unable to come t to roaming which means that apart from on my hotel network and the odd restaurant my phone is unusable.  Am in my own and wanted to use google maps and Rometorio for trips and am now doing everything by paper maps!  And advice gratefully received.  Thx in advance Chris
Christopher_G
Hi @ChrisJuly
Welcome to the community.
Is your plan on contract or pay as you go? What happens when you manually try to connect to an Italian network operator?
