. Mobile data on while abroad but not accepted by phone. How to fix roaming??
PJT2
@PJT2 : Can you make calls & texts?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Does your phone show a connection to any local networks in your host country?
