11-11-2022 08:52 PM
According to the speed check I should be able to get around 30Mb/s but on a good day I can get about 15. Most days it is under 10. I am moderately rural but in Central Scotland. I am using MR600 router. When I had a landline I got about 1. I can see what I think is the nearest EE mast from the house and walking 300m along the road I get about 75 on my phone. I have absolutely zero technical understanding. Is there anything I might do to improve matters?
12-11-2022 10:51 AM
Hi @3weedogs.
You could try changing the position of the router.
Alternatively, you could speak with our Tech Gurus about an external antenna.
Jon
12-11-2022 10:54 AM
Thanks Jon_K
I tried moving the router around but it made no difference. I will talk to the Tech Gurus.
12-11-2022 10:55 AM
Let us know how you get on, @3weedogs 🙂
12-11-2022 11:06 AM
What speed check is this that you're doing? Mobile networks by nature, don't tend to offer predicted speeds - that's usually related to fixed-line connections.
12-11-2022 03:26 PM
I think my original post was misleading. The 30Mb was from the EE site when I looked to see what BB options are available to me. It shows 30 on 4G there.
12-11-2022 06:28 PM
Does an EE phone in the same location get similar speeds?
12-11-2022 06:43 PM
Sometimes. Usually the phone is a bit faster but sometimes they are spectacularly different. The phone tends to be generally a bit faster.
