In Germany no access to Data or calls
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-08-2022 06:19 AM
Network selection is on automatic but not finding any in the centre of Munich. Can’t call EE for help. What to do?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-08-2022 08:04 AM
Hi @DA0370
Can you make calls and send texts?
Are you with us on pay as you go or pay monthly?
Leanne 🙂
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-08-2022 09:15 AM
Hi @DA0370
If pay monthly is roaming, international calls and text active? If not activate via your EE app or online EE account.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-08-2022 10:09 AM
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
- Calls go direct to EE voicemail in Mobile Network discussions
- eSIM transfer from Physical after 'access to brand new standalone 5G service' of in SIM cards & Porting
- Mobile servive in Mobile Network discussions
- URGENT Phone not allowing me to make calls or message 150 in Roaming
- Using an EE sim in the UK in Mobile Network discussions
