I phone 13 and 11 not working in Feurtaventura
GuyWalker01
I have contacted EE and they are escalating it.. been here many times no issues..
but both phones won’t make international calls and WiFi calling not working on international calls either..
we have turned on/off
turned network to manual
reset phone..
any suggestions??
GuyWalker01
Schockwave
@oGuyWalkeyr01 ,Wifi calling only works in the UK.
Have you made sure that roaming, call abroad and premium calls are enabled? You will need to do this by logging into your account, but you will only be able to do this if you are on contract.
If you are unable to do this and everything else you have tried does not  work, you will have to contact EE, which you can do using Skype and their free number:
https://ee.co.uk/contact-ee/account-billing/mobile
@GuyWalker01 , no need to write in two threads, I have replied to your other thread.
@GuyWalker01 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything.
