19-08-2026 04:17 PM
I've recently came back from holiday, I purchased a e SIM when on holiday all was working fine.. I live in an area with terrible internet signal and rely on WiFi calling.. since being home my WiFi calling doesn't work, I've reset the network, restarted phone, re booted the WiFi done all what I can see on Google,
Any other ideas ?
19-08-2026 05:51 PM
@FreeLeeman wrote:done all what I can see on Google,
What have you seen on Google? Can you be more specific.... (we don't know)
19-08-2026 06:06 PM
Hi @FreeLeeman
You say " since being home my WiFi calling doesn't work" when did it last work.
19-08-2026 08:02 PM
Pixel 8 pro
SIM only with unlimited everything
Works as normal apart from when at home using the WiFi calling
Everyone else in house phone works fine so it's not the router or anything
19-08-2026 08:04 PM
Airplane mode on and off,
Restart phone,
Reset network settings,
Pull sim card in and out,
Reboot WiFi hub,
Delete the ESim,
Toggle WiFi calling on and off with airplane mode off
19-08-2026 08:42 PM - edited 19-08-2026 08:43 PM
@FreeLeeman wrote:Delete the ESim,
Does this mean you're now using a pSIM instead? The style of SIM you have is irrelevant, but without an active SIM your phone won't connect to EE's network by any means - mobile or WiFi. You mention in another post "works fine as normal" which suggests you have an active SIM - whether "p" or "e" is immaterial.
You may need to test on another WiFi router to establish whether the issue follows your phone or the router - assuming everything else internet-based works fine and you can connect to EE's network in other locations.
19-08-2026 08:46 PM
I'm using my real SIM card,,, I deleted the ESim which was on phone to make sure it wasn't effecting anything,
It says on my screen EE WiFi calling but only when my phone can actually get phone signal as if the WiFi was turned off. If I'm upstairs in my house I can get one bar signal.. so it says Ee WiFi calling and works fine .. if that's makes sense.
