on 23-09-2025 10:25 AM
on 23-09-2025 11:30 AM
Can you explain the problems you're having with making and receiving calls? What happens when you try making a call? Does your phone show network coverage? When were you last able to make a call?
Are you in the UK or abroad? Are you on PAYG or pay-monthly?
on 23-09-2025 11:36 AM
I try to call, but the call is dropped. They can't reach me either, the call is also dropped. There is almost no coverage or one line. I'm in England. I pay monthly
on 23-09-2025 11:49 AM
Problems making calls could be an issue when you have "almost no coverage". Is this only a problem in one specific location, or is it more generalised?
Can you make and receive calls when coverage is better?
on 23-09-2025 11:55 AM
I'm at home and I don't know how it is in other places, but I can't even call to ee
on 23-09-2025 12:08 PM
A call to EE is still a call.
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage.
