on 26-07-2026 12:28 PM
How do you fix the problem
on 26-07-2026 02:56 PM
Hi @Ajaz11,
Welcome to the EE Community
Is this regarding a PAYG SIM or a pay monthly SIM? Are you in the UK currently? If PAYG what does texting AL to 150 report?
Does the phone show signal? Can you text and use data, just no calls or is nothing working?
Alex
on 26-07-2026 07:02 PM
on 27-07-2026 08:11 AM
Hi @Ajaz11
Please witch your phone off and back on.
Then can you try manually connecting to a different network?
Go to Settings > connections > mobile networks > Network operators > switch "automatic" to OFF. Wait for it to load with networks.
For iPhones it's open Settings, tap Mobile Service (or Mobile Data / Cellular), select Network Selection, and toggle off Automatic.
Once loaded, select a different network to the one you are connected to. wait around 5 minutes before trying to make a test call.
Ali
