How to disable voicemail on mobile phone?
Hezza17
rkelly1
Prodigious Contributor
You'll need to call technical support for that. You'll need to call from another line so you can reboot the phone once they send you an update. Number is 0800 079 8586 from a non EE phone.
9 REPLIES 9
rkelly1
Text 'VM OFF' to 150 is the quickest way
I have tried that a few times but yet I'm still getting voicemails.
rkelly1
Are you getting a reply when you send the text?
If so, what does it say?
It says Your request to turn off your call divert to voicemail has been successful.
rkelly1
Thank you. I have contacted them, and they have turned it off for me. However, I am still receiving them every minute.  It is very frustrating
rkelly1
Did they get you to text VM OFF again after speaking to them? It's worth trying again if they've said it's been deactivated and you're still receiving voicemail.
Yes, I have texted them, but up to date, I have not received a reply from them. I am still receiving voicemails. 😞
Katie_J
Hi @Hezza17.
I'm sorry to hear you are still receiving voicemails, I'd recommend following the advice provided by @rkelly1 and give us another call so this can be looked into further.
Katie
