How to activate phone in Australia
ClaireK39
My phone is showing SOS only since arriving in Australia, yet I activated roaming before I left the UK.
I can’t contact EE as I can’t make phone calls or texts!
In what way did you activate roaming?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Thank you so much for your quick response and advice. The Skype and freephone number tip was super helpful. I called EE, apparently the incorrect roaming had been set up, even though I set up via 150 and selected Aus before we left.
I also had to manually select a network, as you suggested. Vodafone didn’t work but Telstra did work.
Thanks again!
