Aleiahx95
Valued Contributor
Valued Contributor
Hi guys I’m trying to phone my boyfriend he’s on EE none of my messages are delivering and when I call the phone it calls four times like a normal phone would but it’s not a ringing sound it’s like a beeping sound for times and then it goes to the EE voicemail? Can anyone help me? I have severe anxiety trying to figure out what’s going on
11 REPLIES 11
Northerner
Hi @Aleiahx95
It sounds like he has blocked you and refusing your calls.
Aleiahx95
Valued Contributor
Valued Contributor
Hi the call actually sounds like it is ringing through but it is not a ringing tone but it has the same amount of times between the rings then it goes to voicemail??? I have tried calling off another number also and no texts are delivering
What happens when you try calling from another number or with your number withheld?
The symptoms you describe are indicative of your number being blocked.
Mustrum
Maybe the phone is switched off or run out of battery?
Or in a no signal area?
It is doing the same thing with a number withheld and a different number
It’s making a weird beeping noise 5 times like it’s ringing then going to voicemqil
Jon_K
Former EE Employee
Hi @Aleiahx95.
Do you know if he's able to receive any calls or texts at all or are you unable to get in touch to ask?
Are you able to call and text other numbers without issues?
Jon
Aleiahx95
Valued Contributor
Valued Contributor
I am unable to get in touch to ask unfortunately I’m extremely worried 😞 and my calls and texts are fine
Sent from my iPhone
Jon_K
Former EE Employee
Do you have another way to get in touch, @Aleiahx95?
WhatsApp or another messaging app may be an option.
If you've tried form multiple devices it sounds like a problem with their phone.
Jon
