Going to Fuerteventura
supershay2004
Hi. Im going on holiday to Fuerteventura and I have pay monthly unlimited data, txt and calls on my allowance. I see its £2.29 per day. Just don’t understand what I need to do to be able to use my allowance while I’m away. Thanks. Stephen
1 ACCEPTED SOLUTION
@supershay2004 : You may use your usual UK allowances in the EU with up to 50 GB (contract) or 25 GB (PAYG) data per billing month if you have more. If on contract & your contract started after 07/07/2021 there'll be a £2.29 / day charge for using your UK allowances in EU or alternatively you may buy the Roam Abroad Pass for £25 / billing month. If you are going for longer than 10 days it might be cheaper to get the Roam Abroad Pass.
As you are on contract, remember to text ROAMING to 150 before you leave UK to ensure the roaming ability is enabled on your account.
