18-07-2022 09:41 PM
Hi,I'm going to Egypt in August, what's the cheapest way to be able to use WiFi as they only have free WiFi in reception?
18-07-2022 10:30 PM
@Tippyb There isn’t a cheapest way except free Wi-Fi and this has nothing to do with EE or you contract with EE.
If you mean cellular data have a look at THIS and scroll down to the bottom to see what options you have.
18-07-2022 10:39 PM - edited 18-07-2022 10:52 PM
@Tippyb : When you are not using WiFi you will be connected to a mobile signal if you are connected to anything at all.
If you want to make use of EE's (mobile) roaming services & if you are on contract, remember to text ROAMING to 150 before you leave UK to check roaming is enabled on your account.
