Family roaming plan?
Christm79
Hi, is there a family roaming plan? We have 4 Sim only contracts an the same family plan, Is there a cheaper way as a bulk package or will it be £10 a month??
thanks in advance
@Christm79   Unfortunately there isn’t a family roaming plan.  It’s £10 per line to have roaming on any device on your account.
Leanne_T
Hi @Christm79
I can see @Chris_B has provided the correct information, you can find all available add-ons and costs on our Roaming Costs, Help page for the country you are travelling to.
Please check roaming is set up on each number before travelling, to use the phones abroad.
