Roam abroad pass not working
Tach1234
Hello!
I have just activated the Roam Abroad Pass. I had been on the £2 a day EU roaming before but I hit my spend cap. However, despite buying the pass my 4G still doesn’t work. I am in the EU. What should I do to get more mobile data?
@Tach1234 : Can you make calls & texts?
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
