11-07-2022 10:29 PM
Landed in costa rica and had a text to say I could buy add on or swap. I replied to text and keep getting offered music. . I just want to BUY roaming data. Why is it so difficult. Had no data so could not get to my hotel and had to get another room.
So bad
11-07-2022 11:01 PM
Hi @Chocolate51
No taxis in Costa Rica?
You only get 150mb a day anyway so unlikely to be helpful if you intended to use GPS.
https://ee.co.uk/help/help-new/roaming-costs/countries/costa-rica#
11-07-2022 11:27 PM
Yep 6 hours was crazy expensive.
My point is customer services was closed when I called after 8 mins on phone going through options.
When I landed it said the usual welcome then text TRAVEL . reply said it did not recognise the text.
Trying to find buying add on is not easy on site and then when I went to buy it said technical issues, try later.
4 other people I was with had fake issue with EE . My son in O2 was straight in and sorted.
I'll just swap away next month then I'm all good
11-07-2022 11:30 PM
Same issues... not fake i meant
12-07-2022 07:56 AM
Hi @Chocolate51
Welcome to the community.
I'm sorry to hear that you had some problems connecting. Usually when using your phone's browser, it automatically redirects you to our data add-on hub where you can add an add-on.
