08-01-2024 08:22 PM
I just want to clarify my situation. I’m going abroad (in the EU), my phone is set up for roaming and I have a £0 spend cap. I’m aware it’s £2.29 per day for EU roaming and I want to use this. However, will my £0 spend cap prevent me from using roaming abroad.
08-01-2024 10:17 PM
Your phone will still be able to "roam" in the strict sense - of connecting to a foreign network. It will be able to receive texts which is free globally.
Any usage which is chargeable and/or triggers the daily charge, will not work with a £0 spend cap - this means sending text messages or any received or dialled call.
You will need to increase your spend cap in order to use your phone abroad.
08-01-2024 10:42 PM
Yes, your £0 spend cap will prevent any roaming other than receiving texts.
You should bump up your spend cap to accommodate the £2.29 daily charge for as many days as you'll be away if you want to roam fully.
