21-08-2022 12:38 PM
Hi
i bought the £10 monthly roam abroad deal.
to activate do I enable the data roaming? I know that sounds daft as obviously I do need roaming BUT DOES IT RECOGNISE MY PLAN? Or dies it default to the £2 per day
21-08-2022 12:45 PM
@Galini : If you need data while abroad you do need to enable data roaming on your device. Did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
As you've bought the Roam Abroad Pass you wont be paying the £2 per day. It's instead of, not as well as.
