on 03-04-2024 05:51 PM
I finally managed to get data roaming to work in Dubai. I paid 7:85 for 24 hours and after 5 minutes of using it, it ran out. Bought another 24 hours and same thing happened. So £15 for 10 minutes, this can’t be right and really frustrating as just can’t get through to any humans at ee. Does anyone have any ideas what’s happening?
on 03-04-2024 05:57 PM
Data is charged in Mb/Gb not minutes & seconds. the add-ons in Dubai are not for unlimited data but a finite (500Mb in Dubai IIRC) amount of data which is available for upto 24 hours, based on UK-time.
The logical assumption is therefore that you used your allowance in the timeframe you specify. Reset the data counter on your phone next time you purchase a data add-on, to be sure of this conclusion.
on 03-04-2024 05:59 PM
Hi @Nolan1234
The costs and add-ons are here:
https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/unitedarabemirates
£8.45 for 500mb. Expensive and not much data which is both incoming and outgoing.
