10-06-2024 09:36 PM - edited 10-06-2024 09:37 PM
Hi
VM ON is for activation of voicemail and VM OFF is for deactivating the same but what is -
| Control diverts to your voicemail | VM DIVERT ON to turn it on VM DIVERT OFF to turn it off |
I want to turn off VM so should I do VM OFF or VM DIVERT OFF to 150 ?
on 10-06-2024 09:50 PM
Without specific guidance, I would presume this controls the conditional diverts.
Having voicemail active without conditional diverts would hamper its operation, though!
on 11-06-2024 06:58 AM
I’m looking for more details on this because not everyone is using this divert keyboard and most people use VM ON and OFF only.
11-06-2024 07:03 AM - edited 11-06-2024 07:04 AM
@Rky You can use either as both ways control voicemail on or off. Then again you can also use VOICEMAIL DIVERT ON/OFF.
on 11-06-2024 08:06 AM
