Data roaming
Sherry73
Hello I'm in turkey at the mi it's and set up data roaming before I left I have no signal and. Any make calls I don't have data roaming option in my setting iPhone 15 pro max  can anyone help please
Christopher_G
Hi @Sherry73
Welcome to the community.
Have you tried manually connecting to a different available network? When you say you set up data roaming, was that the option in your phone settings or through EE?
@Sherry73 : Data roaming is not the issue nor is the settings on your phone. You need roaming in general to be enabled on your EE a/c.
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Data roaming simply means using mobile data whilst roaming. To extend the logic, there's no phone setting for voice-call roaming or text-message roaming - as mentioned already, the crucial setting is at account/SIM-level and is "roaming".
This enables access to foreign networks, thus allows your phone to get coverage abroad - which unlocks the ability to roam. be that data roaming, text-roaming or voice-roaming.
