on 12-10-2023 09:17 AM
Hi I have flown to Spain today and I am not able to receive data roaming can you help me please?
on 12-10-2023 09:21 AM
I want to turn this on, on my phone but it won’t let me?
on 12-10-2023 09:38 AM
Data roaming just means using mobile data whilst roaming, can you voice-call roam or text message roam? Does your phone show a connection to any Spanish networks?
In order to use your phone abroad, you need roaming activated to enable a connection to foreign networks. Are you on PAYG or pay-monthly? The process differs, but it's not a phone setting you can change.
If PAYG - this is auto-enabled once your phone is used on EE's UK network first.
If pay-monthly - this needs enabling, usually by texting ROAMING to 150 before leaving the UK. Did you do this?
on 12-10-2023 09:41 AM
My data isn’t work in Spain my settings hasn’t got the option of data roaming either
also I have a data roaming on add on on my contract
on 12-10-2023 09:45 AM
Your billing add-ons are irrelevant, they're just to reduce the cost.
As per my previous post...
on 12-10-2023 09:47 AM
I am pay monthly but my settings won’t let me activate it and I have text 150 but they haven't helped I do need this roaming for work
on 12-10-2023 09:54 AM
You've still not answered whether you texted ROAMING to 150 before leaving the UK, that's the only setting that matters - anything else is futile. If you are on pay-monthly and have travelled abroad without enabling roaming, your phone will not connect to any foreign networks and any phone function that uses a mobile-network-connection will fail.
Your only recourse now is to contact EE CS from another means - either another working phone, or +44 800 0798586 from a web-calling app such as Skype, and request roaming is activated.
