Dat
Sarahevs79
I'm In Greece and have unlimited calls texts and data but can't call out as I get a message saying unauthorised selection please help fix this as I have paid for the data roaming pass
7 REPLIES 7
Schockwave
Hello @Sarahevs79 ,
Welcome to the community,
Did you enable roaming on your account? This you would have needed to do if on monthly contract before going abroad.
Pay as you go would be enabled.
Have you tried a manual search for network?
@Sarahevs79     Purchasing add ons doesn’t enable roaming these are different things.    The amount of allowance your tariff gives you is not relative to this.  Plus you can only use 50Gb of your unlimited data allowance when abroad per month.
So what is the answer to the query? How can someone make calls??
Alex_M
Star Contributor
Star Contributor
Hi @SarahM85,
Before going abroad you need to text ROAMING to 150 to enable it for your pay monthly sim.
Thanks,
Alex
 If I solved your issue, please click the solution button below!
 If you found my post useful, click the thumbs up button!
 To speak to EE, call 150 from your EE mobile or +44 800 079 8586 (freephone) or start a live chat.
Useful Links: My EE | Live Chat | Bills | Usage | Network Coverage Checker | Abroad | APN Settings | PM
Thanks Alex - so if calling uk from Greece is it +0044 the the number without the 0?
Alex_M
Star Contributor
Star Contributor
@SarahM85
Yes if you're calling the UK from greece you can call 0044 instead of the 0.
You can also just do +44 using the + button on the phone's keypad.
For example instead of 01234 567 890 you can just dial:
  • +441234 567 890
  • 00441234 567 890
Both should work 😊
Thanks,
Alex
Many problems with making calls whilst abroad can also be resolved by manually changing to a different local network - or toggling flight mode.
If that fails to clear, then changing the dialling code as suggested, is a good part of troubleshooting.
