Connect to network
Mrsninja
I'm in Florence and can't access the ee network have turned roaming etc on and turned phone off and on again but can't make calls and can only connect to hotel WiFi
21 REPLIES 21
Hi both, I'm in the same situation, in Italy as well.
I've tried manually selecting the roaming networks (Vodafone and 3ITA) but it says 'couldn't connect'. I've also tried restarting my phone/turning Romanina in and off, etc
James_B
EE Community Manager
Hi @Ninitegou,
Has your phone been working previously in Italy or has it not connected since you arrived?
Thanks for your reply. It was working perfectly fine until a few days ago
and I've had no problems during previously trips to Italy.
Thanks,
Valentina
James_B
Have you been able to test your phone in more than one location @Ninitegou?
Yes I have, in many different places around my area.
Hi @Jon_K
Unfortunately, it does not work. It stopped all of a sudden - I am wondering if there is an issue with the provider in Italy as it would appear I am not the only one experiencing this problem. What is even more frustrating is that I am unable to contact EE in anyway as all calls and messaging functions are unavailable.
Any help would be greatly appreciated.
Thanks,
L
James_B
Did you try a manual network search @LuisaIT?
For iPhone, go to Settings > Mobile Data > Network Selection > Turn off Automatic
For Android, go to Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Hi I am now in Venice logged onto I Tim but it keeps dropping out I presume there's a problem in Italy do you know when or if it is going to get fixed?
James_B
Are you able to connect to Lliad @Mrsninja?
