Cannot call UK or receive calls from UK when in Turkey
barisari
I turned roaming and everything related on and have no spending cap. Still, cannot receive calls from UK when I am in Turkey. I cannot call UK numbers either. But strangely, I can make international calls. This is so weird. How to fix this?
Looking at the forums, it seems like this is one of the endless EE technical errors. I cannot call them from here. Is there any other solution?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
10 REPLIES 10
Northerner
Hi @barisari
If you can make international calls then try adding +44 before the number.
Costs for using your device in Turkey are here;
https://ee.co.uk/help/help-new/roaming-costs/countries/turkeyandnortherncyprus
How will this solve my problem of not receiving calls from UK? Please at least read the question before pasting generic web pages. And of course, I am putting +44.
I appreciate if you can delete your answer because it is just wasting space and everyone's time. These unrelated, generic, and unhelpful replies are so annoying when you are trying to find an answer to a question.
I am on contract. I was using the SIM regularly before going abroad.
I activated it through the app. I am not sure if it was already active when I was in UK or I activated afterwards, but it is definitely active according to the EE app.
I tried reseting the device and selecting the network manually. Did not make a difference. Roaming Abroad is ticked. Call Abroad was not, but this option clearly states that it allows making international calls while in the UK. This is not what I want to achieve. I would like to receive calls from UK while I am abroad.  I activated just in case, but if this is the problem, EE should fix this because it is clearly misleading.
I can see when someone from UK is calling, but I cannot answer the call. It quickly says call failed after one ring.
Thank you for your answerç
Leanne_T
Hi @barisari
Thanks for coming here.
Can you send and receive texts to UK mobile numbers?
Have you tried restarting your phone?
Leanne 🙂
@barisari , firstly, the SIM card has to be activated in the UK first, also call abroad and premium calls have to be ticked, otherwise you will not be able to use the SIM card as planned.
If you are unable to allow call abroad and premium calls, then if you have Skype, you could call them:
https://ee.co.uk/contact-ee/account-billing/mobile
As you have written you are on contract, so I would have thought the SIM card is active and it just has to do with call abroad and premium calls, which need to be ticked, hopefully you are able to do so.
barisari
Activating "Call abroad while in the UK" solved my problem, but this option is definitely misnamed and misleading because my problem was being unable to receive calls from the UK while abroad. Thanks @XRaySpeX and everyone who tried to help.
Leanne_T
Thanks for the feedback and for letting us know this is now sorted for you @barisari
Leanne 🙂
@barisari , thank you for coming back and letting us know, glad that call abroad while in the UK solved your problem, hope you enjoy the rest of your stay in Turkey, and you are welcome, that is what we are here for, to help where possible.
