on 29-01-2024 05:00 PM
In Ukrain I can't send and receive text.Can call. PAYG, used this SIM in UK.
Solved! Go to Solution.
on 30-01-2024 10:24 AM
Thanks @alyrasan
Can you try manually searching for a different network, do any show available for you try?
29-01-2024 05:20 PM - edited 29-01-2024 05:20 PM
@alyrasan Have you restarted the device since you got there ? You are putting 44 or +44 at the start of the number if you’re trying to text a UK number? I assume you have credit on the account to pay for these texts ?
on 29-01-2024 05:25 PM
Had you used that PAYG SIM for making calls or texts in UK before you left to go abroad? To be used abroad EE PAYG SIMs need 1st activating on EE's home UK network. If it wasn't you can't now use it until you return to UK.
on 30-01-2024 07:26 AM
I used that PAYG SIM for making calls or texts in UK. I can't receive or send only texts. I restarted my device 2 time. Don't help.
on 30-01-2024 07:29 AM
Hi.
I can't receive texts for go my acounts. I restarted my device 2 time. I assume you have credit on the account to pay for these texts ? - Yes. 29.
on 30-01-2024 08:44 AM
Hi @alyrasan
When was the SIM last used to make a call, send a text or topped up?
Can you make calls?
on 30-01-2024 09:58 AM
I made some calles 29.01.2024. But I can not send or receive texts.
on 30-01-2024 10:00 AM
I can call, but my text is not received and I do not receive its.
Thanks @alyrasan
on 30-01-2024 10:39 AM
Thank you so much!
