15-08-2021 11:43 AM
my phone is telling callers it’s switched off. It’s not. It’s not on silent, airplane mode or do not disturb
15-08-2021 03:41 PM
Thanks @Jukeboxjulie, I would like to try doing something called a network refresh, to do that please follow the below instructions:
Step 1. Tap the Settings app on your iPhone.
Step 2. Tap General.
Step 3. Scroll down to find Reset and tap it.
Step 4. In the new window, select Reset Networking Settings and confirm the action.
Once you have followed these steps you will need to re-enter any WiFi passwords you have saved. Please let me know if this helps over the next couple of weeks.
15-08-2021 12:30 PM
@Jukeboxjulie Does it show a signal on the device? Have you tried just restarting the device?
15-08-2021 03:31 PM
Yes I’ve done a forced reset and got a signal. This has been occurring over the last 3 weeks.
15-08-2021 03:36 PM
Welcome to the EE Community 😊
I hope you're well and having a nice weekend, other than this issue of course.
Could I please check what make and model phone you're using?
15-08-2021 03:38 PM
I’m using an iPhone se
15-08-2021 03:41 PM
15-08-2021 05:19 PM
Can you make outgoing calls ok?
15-08-2021 06:30 PM
Yes I can make calls no problem. I think it’s sorted now though thanks
15-08-2021 06:36 PM
I think that might have resolved it. Well, at least I’ve had a call off someone that couldn’t get through b4. I’ll monitor the situation.
thankyou
15-08-2021 06:38 PM
For the benefit of other users who may come on this forum seeking a fix for the same issue, what was the resolution?
