Can’t call UK from Spain
jay_phd
I am unable to call the UK from Spain despite roaming being turned on my iPhone and my account on MyEE stating the roaming is activated.   Phone is connected to local provider (Movistar) and showing 3G (data works fine).  Never had this issue with EE in the past.  Tried turning the phone off and on again and changing MyEE setting off roaming and back on again, but still no luck.
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
@jay_phd   Have you enable call abroad and make premium rate call ? This also also within the roaming settings on the my EE app.   Also on your iPhone within Settings>Phone is dial assist turned on ?  If it’s not you need to make sure you are dialling 44 at the start of the number you are calling and not 0
jay_phd
I had to enable the setting “allow overseas calls from the UK” (despite not being in the UK but this seems to have resolved it.  Perhaps the setting should read “allow overseas calls.”  Hope this help others.. 👍🏻
Leanne_T
Thanks for sharing @jay_phd
Have a lovely time 🙂
