on 25-08-2022 10:12 AM
Hello
on 25-08-2022 12:13 PM
on 25-08-2022 02:27 PM
on 25-08-2022 02:42 PM
on 25-08-2022 03:17 PM
on 25-08-2022 03:28 PM
Is roaming enabled on your device?
on 25-08-2022 03:37 PM
on 25-08-2022 03:56 PM
on 25-08-2022 07:57 PM
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
