Calls to & from Vodafone
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
25-11-2023 03:22 PM
Hi
I am unable to make or receive calls from and to mobiles on Vodafone
this has been happening for a few days and only happens when I am on a mobile signal. When using WiFi calling everything is fine.
I have checked two EE mobiles and 2 Vodafone ones and it does seem to be an EE issue.
as mentioned here
Thanks Ian
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
25-11-2023 03:33 PM
The issue in the article has long since been resolved, also it would be unusual for call routing symptoms to be different between VoWiFi & VoLTE, as they use the same central network elements.
An inability to call certain networks would have a different cause to being unable to receive calls from certain networks. What happens when a caller is unable to reach you?
What happens when you try calling someone?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
25-11-2023 03:51 PM
Hi - all other calls work fine - it’s only to and from Vodafone (haven’t been able to try O2) but landlines and 3 are ok.
I’m in Filton, Bristol now and it isn’t working, I’ve tried in the centre of Bristol, Weston SM and near the airport, all failing (so not a mast) - am on 5g now with an iPhone 12 Pro Max
I understand that the issue is the article is supposedly resolved but found it very interesting that the WiFi calling works - so there is a VoLTE/VoWifi connection…
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
25-11-2023 04:01 PM
Unless there is an interconnection issue with VF - which would cause significant volumes of posts on this forum - the two issues are likely to be unrelated.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
25-11-2023 04:15 PM
Hi
when they try to call they get silence and then the call disconnects- no answerphone. I get the same the other way.
just switched off data and the call worked - iOS 17.1.1 doesn’t seem to have a volte setting any longer but it seems VoLTE is the problem
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
27-11-2023 06:40 AM
Hi - this was still happening yesterday, it appears that VoLTE doesn’t work when calling some other networks. I can call geographically and can call three. VoWiFI works as does ‘normal’ 2g calling.
it does remind me of issues I was having in US (search my other posts) - could there be an issue with my account/Sim??
thanks
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
27-11-2023 08:12 AM
Hi @IDW
It may be worth having a chat with our technical support team so they can check everything from our end and run some tests with you.
