25-10-2022 09:48 AM
Over the last few weeks/months, i've been noticing that calls are cutting out after 15 minutes- not just related to one particular number. Its extremely frustrating. Signage coverage is good, and I am not calling by wifi/internet.
What would be the reason for this happening? And can this be fixed somehow. I'm using a Samsung Galaxy A-40.
27-10-2022 07:59 AM
Data roaming simply means using data when using a network other than your own, such as when abroad.
VoLTE means making voice calls over 4G, and has nothing to do with mobile data.
Voice calls do not use data, I would strongly recommend enabling VoLTE as it can also lead to coverage improvements in some cases.
03-12-2022 06:11 PM
Hi, I've had exactly the same problem with my phone as well. I had this issue with my Pixel 6 Pro, and now I still have the same problem with my new Pixel 7 Pro. It's not related to any phone setting as I've tried phoning using WiFi, using the phone sim and a number of other settings, but always the same result, after 25 minutes (give or take), I get cut-off, I call again and everything seems fine for another period. Not sure what's going on so if anyone has any ideas, "speak up".
04-12-2022 08:30 AM
Welcome to the community, @MrBee.
Have you spoken to our Technical Support team about this yet?
