Call forwarding error
blablabla123
I am trying on my phone the call forwarding to another UK number and it always fails.
When I try from the settings, the following error appears: "call settings error unexpected response from network".
This is regardless if I want to set 'Always forward', 'Forward when busy', 'Forward when unanswered' or 'Forward when unreachable'. Is there anything I can do?
When I try using codes, the following error message appears: "Operator message, Call forwarding, Connection problem or invalid MMI code. (0).".
Is there a solution for this? Thank you
Thanks for the advice Chris.
I have contacted the technical team who checked my account and switched the call forwarding on. As it was off I could not do this and I did not receive any indication either that it was off. Once it was turned on, it started to work immediately.
Would be good if it was available to be turned on/off through MyAcco**bleep** or it would be turned on by default.
Anyway, many thanks for your help
8 REPLIES 8
Are you on PAYG or pay-monthly?
Pay-monthly
Christopher_G
Hi @blablabla123
Welcome to the community.
What kind of phone are you using?
Hi Chris,
I have a Sony Xperia 1 iii what I got it from EE on 27-10-2021. It is fully updated, on Android 13.
Thanks, George
Christopher_G
OK, thanks @blablabla123
I'm not sure why it isn't working for you. It may be worth speaking to our technical support team so they can check your account is set up and run through some troubleshooting with you.
Thanks Chris.
I will get in touch with them and report back one we reach a conclusion. It is very weird, agreed as it should work...
George
James_B
EE Community Manager
Glad you got it sorted @blablabla123
Thanks for coming back to let us know. 🙂
