on 10-04-2026 02:34 PM
Recently I've started receiving an error stating "Mobile Data Is Not Available During This Call".
However ever since upgrading my tariff to an All-rounder tariff back in October I've found that my signal and data speeds seem to have decreased and gotten worse. Along with upgrading my tariff I also upgraded from an iPhone 14 Pro Max to an iPhone 17 Pro Max.
Is there any setting or anything I may need to change to get the full potential from my phone?
I just seem to think it's weird that I get a worse mobile service on an All-Rounder plan than I did on the capped Essentials plan.
Cheers!
Solved! Go to Solution.
11-04-2026 09:45 AM - edited 12-04-2026 09:48 AM
Thanks for getting back to us, @Patty37.
When you're on a call, does your phone stay on 4G or 5G, or does this change?
If 4G or 5G is still showing during the call, you would normally be able to use data at the same time.
If you’re still having issues, I’d recommend getting in touch with our customer support team, who can run through further checks to help.
Debbie
on 10-04-2026 05:11 PM
HI @Patty37
To fix "Mobile Data Is Not Available During This Call" on an iPhone, ensure VoLTE is enabled by going to Settings > Cellular > Cellular Data Options > Voice & Data and selecting VoLTE to on.
Then restart your device.
If you still have a problem, does this only happen in your home area or in other areas/towns too?
If its only in one area, you can you can check coverage and network status at Check mobile coverage where you can also report any issues you are facing.
Ali
on 10-04-2026 06:13 PM
I don’t have those options. Please see the image below of my settings. And yes this happens in multiple areas in the outskirts and city centre of Aberdeen.
Debbie
