Call Forwarding if unanswered after !!! amount of rings
wombat23
Hi I know how to set call fwd if not answered using the *21*mobilenumber#  however it rings 1.5 times then call fwds. I need it to go after around 7-8 rings, It did this before we went abroad and now I cant figure it out again I know its some extra * and a number at the end before the # but I cant get it to work . Help appreciated .
FIZZYLP
Skilled Contributor
Skilled Contributor
Hello @wombat23
Check out these help pages for more Guidance.
Article 1.
Article 2.
Hope this helps!  If you like my reply and want to say thanks for the helpful answer then please click on the Kudos on left hand side  also if I answers your question correctly please let us know by clicking on Mark as Accepted Solution 
